Re: Chemical Help
I am still getting super high CC levels.....
I have been able to get my FC up to over 10 at times but my CC level has been on the rise. I have gotten CC readings that seem to be outragous from what I have read on this forurm... over 11 at one point but not that high now. I still get in the 5-7 range which is still a very high reading. I did use a commercial "shut down" package from In The Swim before shut down in the fall. Could this effect my CC numbers??? Is there an end in site???
Recent Measurments:
FC 6.5
CC 7
pH 7.6
Is there ANYTHING I could be doing wrong with the Taylor test that could be giving me a false positive for CC? My powder that I add 2 scoops is not a fine powder but rather small crystals and does not dissolve real well. Most times it will not fully dissolve no matter how much i swirl.
My water is rather clear with sediment on the bottom and no odor?
Thanks,
Mike
