Thread: How Much Bleach
    Apr 2012
    Ohio
    Default How Much Bleach
    My current levels are;
    FC 2.5
    CC 0.5
    TC 3.0
    PH >7.0 (I just finished dropping my ALK and aeration is ongoing)
    TA 90
    CH 80
    CYA 55
    How much Walmart 6% do I need to add to get a 2.0ppm rise? Is there a standard calculator located on the forum?
    My pool is a AG 17,500 gallon.
    17,500 Gallon above ground, Hayward 150 pound sand filter containing 75 pounds of Zeobright, 1.0 HP pump, Rheem natural gas heater
    My results are generated from a Taylor K2006 kit.
    27' round 17.5K gal AG pool; Bleach; Hayward 150 pound sand filter; Hayward 1.0 hp pump; 12hrs; Taylor K-2006; well; summer: ; winter: ; iPad; PF:6.9
    Apr 2012
    Ohio
    Default Re: How Much Bleach
    Sorry, the Ph is less than 7.0, not greater than.
    In 17,500 gallons of water, each 2.5 quarts of 6% chlorine should give you just over a 2 ppm chlorine rise. There are a couple of pool calculators you can use--one is www.thepoolcalculator.com, and the other one is Bleachcalc. I prefer Bleachcalc for ease of use, but I have it set on my desktop so I'll have to look around the forum for the link to it. When I find it I'll try to come back and post it here.
    Apr 2012
    Ohio
    Thanks Watermom, my Ph is now just over 7.0. I've had good luck with aeration.
