Thread: Need to shock after "Babe Ruth" incident?
    May 2011
    Salt Lake City, UT
    Default Need to shock after "Babe Ruth" incident?
    Had the grandkids over this weekend, and I am not sure if it was a babe ruth laying on the bottom of my pool or something else
    I think I was able to get most of it out of the pool, but want to know if i need to shock the pool. I am still in the process of getting everything stabilized this spring, so I actually had a higher level of FC than I would normally run, but wondering if I need to raise it again. My FC is 6.5 with a CYA level of 30. PH is 7.6, TA and CH are a little high at 90 and 390 respectively. (I have an inground gunite/plaster pool with a SWCG).
    Default Re: Need to shock after "Babe Ruth" incident?
    Yes, I would go ahead and shock it--just overnight. Odds are that the chlorine levels you already had have taken care of whatever may be in the water, but just to be on the safe side, shocking is easy. Stuff happens....
    BigDave's Avatar
    I'd also leave the tool used to remove the candy in the pool during the shock to get it good and clean too.
    Also, if you are using cal-hypo, you might want to find other forms of chlorine to use. You're reading is ok for now but if it gets too high you may have cloudy water issues. Usually a calcium reading of 200-400 is what is recommended.
  1. 475 gallons, how much powder "Ultra Shock" to use??????
    By Shannon84 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-18-2012, 03:35 PM
  2. What would "shock level" be considered?
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-15-2012, 02:45 PM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. when is it safe to swim after "shock"?
    By kjmelak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-06-2006, 08:47 AM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
