I don't mind your posting, and asking here, but you do realize that this is PoolForum.com, not TroubleFreePool.com? As far as I know, there's nothing wrong with the TF-100 -- it's a nearly identical copy of my PS-235, which I abandoned when I nearly went bankrupt several years ago. But that's their kit, not mine.
What we do object to, is running two identical threads, one here, and one there. Please don't do that! They also teach my BBB method, and you'll get similar information there from what you would here.
Turn off the SWCG, and start bleaching! SWCG's aren't really optimal for pool clean up, and it wears them out more quickly. Your high CC level tells me something is wrong. Keep the pH between 7 and 7.8, while you're bleaching. If you have reason to think you might have metals in the water, keep your pH to the LOW end of that scale.FC--2; CC--6.5 (our pool store is having us run the cell at 90% right now to "clear up the green after a couple weeks")
What is your CYA level, now? And, what was it, last year?
