Re: Green hue in clear water...
Pool store had my husband put in algicide as soon as we took off the cover. I have no idea what kind. He just did what he was told and threw out the bottle and he doesn't remember. Probably the same kind they had us put in last year...no issues last year??
Pool is darker blue finish...not white.
I asked the pool store about testing for metals and they said they did and it's fine. However, the print-out showed cooper and iron as "not run"???
Yes on skimmer pill...same kind as last year with no issues. You do mean the thing that helps prevent water loss from evaporation, right?
No heater, no ionizer, water comes from city, some of original water also came from spring...long story, but pool companies idea to speed up install. We didn't have any trouble then, nor last year, which was our first full season. Any water added since then and the majority of ariginal water is city water.
I did get the new tube and my CYA reading was the same as pool store at 55 ppm. This was yesterday and I suppose it's possible that it's gone up a bit more...had expected it to increase to 70 with the amount I added (added second 4 lbs on Wednesday).
Had trouble finding 2 boxes of Borax, but finally found a second box. We will be working on the pool for the rest of the day now that we are back home!
Thanks again for all of your help! Should I wait the same 2 hours to test the salt again or should I be more patient with this stuff?
The ideal ppm for FC in the aqua rite book is 1.0-3.0. Is there a reason you suggest keeping it at 4.0?
I'm trying to learn and absorb everything each of you is teaching me and it helps when I understand the reasons behind your logic. I've been passing info on the my husband, but he doesn't really want to know how it works. He just wants it fixed...lol
