Thread: Fill with only 1 foot of water and don't fill for 24-48 hours?
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    Default Fill with only 1 foot of water and don't fill for 24-48 hours?
    So my installer is coming tomorrow and I asked a few questions and one of the things that came up was that once the pool is up, I should fill it with 1 foot of water and leave it with just that foot of water for 24-48 hours.
    I guess part of it is to give a little time to inspect the pool and liner, and that way if there is something wrong I don't have to drain the whole pool and buy the trucked in water again.
    Just wondering if this is typical with installs. Should I put some liquid chlorine into that foot of water to prevent algae growth until the time I get the rest of the water trucked in?
    Wilbar/Sharkline Tahitian 23,900 gallon 30' Round AG, Hayward 1HP 2-speed pump, Hayward 300# Sand Filter, Taylor K2006c.
    Default Re: Fill with only 1 foot of water and don't fill for 24-48 hours?
    Yes, by all means, put some bleach in. But, since the water is so shallow, and since there's no circulation, take a 5 gallon bucket, or small garbage can, and mix 1/2 gallon of bleach into 2 - 3 gallons of water, and then pour it around the pool. Take your fill hose, and wash off the splatters. Don't do this with nice clothes on -- you're likely to spatter, and bleach is very hard on clothes if it's a little concentrated.
    Aug 2011
    Massachusetts
    I'm actually using liquid chlorine so does that mean 1/4 gallon in 2-3 gallons of water? The liquid chlorine actually comes out cheaper than bleach at Namco when buying in a 5 gallon jug.
    Install didn't go too well. Pool is up and looks great but the installer cracked a PVC drain pipe that was buried in the ground. I called a buddy of mine and he already fixed it for me.
    Good thing I paid the town Board of Health and Building Department all that money for those permits to make sure where I was doing my dig was safe. They marked out the leaching field, septic, and distribution box. I already knew where leach field and septic were but I had no idea about the distribution box...apparently neither did they...lol.
  1. If this was your fill water, what would you do?
    By Bosch232 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2013, 09:13 PM
  2. Testing fill water
    By Budlight592 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-10-2012, 06:55 PM
  3. High TA in fill water
    By AndyJ in forum Dealing with Alkalinity and Calcium
    Last Post: 06-10-2010, 11:01 PM
  4. Tested my fill water
    By Rangeball in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2006, 12:47 PM
  5. City or well for fill water
    By StevenW in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-22-2006, 09:29 PM
