Results 1 to 10 of 22
Thread: Pristiva Primer and Activator
    May 2010
    Default Re: Pristiva Primer and Activator
    We just work pretty hard to slam the door on new mystery goo products -- we see several new ones each year. To date, since the inception of the forum, we've not seen a single such product that turned out to be worth the money. AND, we've seen many that turned out to be harmful to your pool.
    Keep up the good Work, Ben! The education and awarness you publish is huge. There is no lower feeling than to have your kids or grandkids look you in the eye and tell you that they don't want to swim in your pool anymore because their eyes burn or its too dirty etc. I was there a few years ago. I refuse to let my family swim in Toxic Waste ever again!
    Apr 2012
    Fulshear, TX
    My kit came in this weekend and I have some test results for yall. I had some issues getting the Combined Chlorine. Here are the numbers:
    FC - 5ppm
    CC - ?? When adding the drops of the R-0003 regent, the sample would not turn pink. I added up to 15 drops and it stayed clear the whole time.
    PH - 8
    Minerals - 330ppm - per K-1766 test kit.
    CH-410
    TA - 120
    CYA -35 - This is surprised me a little and I did it twice. When I had my water tested last week at the store they had said 30, then came back with a 60. Per Hayward, my pool should be at 70-90 ppm
    As for my pool specs, 26,000 inground, Hayward Goldline Pro Logic Controller, Aqua T-Cell 15 SWGC, Hayward DE 6020 Filter, and Hayward Tri-Star 2.70 HP Self Priming Pump. I am currently running my pumps 13.5hrs. 9hrs at 85% on pump speed then 4.5 hrs at 45% pump speed. My chlorinator is set to 75%.
    I had a slight algea issue last week and it has not re-appeared after treatment. I am just wondering if there is anything I can do to make my pool trouble free this summer. Last summer (my first as a pool owner) was not pleasant. I was dumping all sorts of chemicals in the pool trying to get it balanced.
    Any assistance or advice is greatly appreciated. At the moment, the pool looks great and the water is clear.
    27K IG free form with spa; Hayward Goldline Pro Logic controller, Aqua T-Cell 15 SWCG, Hayward DE 6020 60sft filter; Hayward Tristar (Ecostar?) Pump.
    Quote Originally Posted by cjryan33 View Post
    You only need a drop or two. Your result just means you had NO CC . . . which is a good thing.
    Ok. With a 26K pool, your PF is 4.5
    Do this.
    1. Turn your SWCG off -- you're just wearing it out, at the moment.
    2. Get 2 gallons of muriatic acid, and lower your pH. Read the muriatic acid page first. Add 1/2 gallon at a time; wait 4 hours; test; repeat till you reach 7.6 or below.
    3. CAREFULLY re-read the instructions on your K1766; make SURE you are doing it correctly, and then re-test. If you really have a salinity of 330ppm, your SWCG should be in alarm. (Meanwhile, do #1 above!)
    4. Dose your pool with 4 gallons of bleach each evening, till you get dichlor OR get stabilizer above 50 ppm and salt above 3,000 ppm.
    5a. Get 50# PoolBrand dichlor at Sams Club, OR at Amazon
    5b. Buy some stabilizer locally or at Amazon.
    5c. Buy dichlor at Amazon (do NOT get it locally, except from Sams -- most are now hodge-podge mystery blends!)
    ===> To add 40ppm CYA, you need about 9lbs of stabilizer or about 20 lbs of dichlor. Using dichlor will BOTH chlorinate AND add stabilizer AND lower your pH, so it's a very efficient choice for you, at the moment =======
    Get back to me, on your results and actions.
    Apr 2012
    Fulshear, TX
    Im sorry, I had a typo. My salinity is 3300ppm
    OK, good!
    Apr 2012
    Fulshear, TX
    Alright Doc,
    I turned my SWGC off. This morning I added on gallon of Liquid Chlorine before leaving for work( already had this) it is labled Shock - Chlorinating liquid for Pools and Spas. The wife added a 1/2 gallon of muratic acid and 3lbs of BioGuard Stabilizer 100 (already had as well) next trip to Sams will be picking up the Dichlor. Got home and added 3lbs more of Stabilizer and 1/2 gallon of acid. After swimteam came home and tested. The results are as follows
    FC - 6ppm
    PH - 7.3
    CYA - 55-60. All of the stabilizer may not be dissolved as of yet. Thank you for your assistance.
    Coach, swimmer, or parent? Summer league or USS?
