Results 1 to 10 of 32
Thread: cloudy water
    Apr 2012
    AL
    Default Re: cloudy water
    Just thought I would post a update real quick. I put 2 gallons of bleach into the pool, and then 3 tablets into the skimmer and filled the chlorine floater up with 4 of my tablets. The 3 tablets in the skimmer already dissolved when I got home late last night and the 4 tablets in the skimmer were just dissolved a small amount. They might have all 4 gotten about a half inch smaller. Thats with the floater opened all the way and I always run the pump 24 hours a day 7 days a week.
    Anyway, It's amazing how much more clear the pool is. I can easily see the bottom on the shallow side very clearly and I can see the bottom on the deep side although the deep end is just a tiny bit cloudy still... I'll test the pool numbers with my Taylor K0006 kit when I get home from work late tonight and post them up and see if you guys think I should make any changes...but otherwise I think everything is coming along great. I've got to run to the local pool place today and pick up a new vacuum hose since mine has a broken end and wouldn't stay attached very well when I vacuumed the other day. I can easily see the sand/dirt every where that I missed when I vacuumed blindly in the cloudy water...but from what I can tell...I dont see any algae anywhere at all. Just dirt.
    Oh, and one more question. There is a underwater light on the deep end of the pool that's built into the pool wall and the bulb blew. Is there a standardized size for pool bulbs that I can use for a replacement?
    20K Gal Vinyl Liner IG Pool (16' Wide x 32' Long & 8' Max Depth)
    Hayward S244T Filter
    CL200 Feeder
    1.5HP Up-Rate Super Pump
    Quote Originally Posted by Zac851 View Post
    Replacing pool bulbs can be very tricky. The bulb may be standard, but the lamps are not. You need to make sure you know the type of lamp, and that you have replacement gaskets available BEFORE you try to remove the lamp. Otherwise, wait till you don't mind if the pool is unusable for 2 weeks, because you've got a messed lamp and wires in the water.
    Apr 2012
    AL
    Just got home and tested with my k0006 kit.
    Free Chlorine - 1ppm
    Combined Chlorine - 1ppm (I thought these would be different)
    pH - 7.3
    Total Alkalinity - 90
    CYA - 0
    I'm about to go add 2 boxes of the Borax that you said to add and then test later on tonight before I go to bed. I was always under the assumption that 7.2 pH was great but after reading your link - http://www.poolsolutions.com/gd/hiphpool.html I'll just take your word for it.
    I'm still a little confused on CYA though. I understand its a chlorine stabilizer but why don't I have any traces of it in my test? Is there not any CYA in my 3" chlorine tablets?
    Either way I know the Cholorine numbers need to come up or I'll be back green shortly. I think I read on here somewhere that 5-10ppm was idea? What do I need to do next? I was going to add the borax tonight and test pH in the morning and I guess I need to get the chlorine numbers up and add the stabilizer to it. The closest pool store to me is a leslies pool supply. What is the best CYA to pick up from there? I've got to go there in the morning to get a vacuum hose since the pool place I stopped at today only had 40+ foot hoses.
    CL200 Feeder
    Apr 2012
    AL
    Oh forgot to post pics of how clear its looking as of 20 minutes ago. Thank goodness I didnt pay the pool place the $500 they wanted to do everything.
    Entire pool with algae dust
    Steps with algae dust
    CL200 Feeder
    Glad it's working our for you!
    Apr 2012
    AL
    Ok so I added one four pound box of borax just to see how much pH would rise from 7.2 on my last test and two bottles of bleach (1.42/each) before bed and checked it this morning. I grabbed my cheap Walmart kit rather than my Taylor kit which I'm thinking was a bad idea. It looked like chlorine was 4ppm and I couldn't tell a differnce between free chlorine and combined chlorine and I got what looked like almost 8.0 on pH. I don't see anyway that pH came up that much from one box of borax. I should have used my Taylor kit. I'll test again when I get home in a bit to see what I get.
    CL200 Feeder
