Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 44
Thread: Test Results - Please Review
  1. #31
    Default Re: Test Results - Please Review
    Trucked in water didn't have CYA in it -- it's NEVER used in potable water treatment.
    Stabilizer dissolves slowly, so what you added 4 days ago is only now fully dissolving. If you added granular stabilizer yesterday, you'll probably continue to see a rise in CYA levels over the next few days.
    As a rule, a drop in filter pressure means a drop in flow, often because of a dirty strainer basket, or a clogged impeller. Is that a possibility on your pool?
  2. #32
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    How would it have climbed this high in the first place though? I definitely did not use enough stabilizer to get levels that high. I used 1 gallon of this:
    http://www.intheswim.com/Pool-Chemic...r-Conditioner/
    And 3 lbs of this:
    http://www.walmart.com/ip/HTH-Stabil...Specifications
    In a 23,900 gallon pool that should have given me around 30ppm or so....not 55.
    Wilbar/Sharkline Tahitian 23,900 gallon 30' Round AG, Hayward 1HP 2-speed pump, Hayward 300# Sand Filter, Taylor K2006c.
  3. #33
    Partly, you're overestimating your gallons. Pool companies always quote volume at the 'running over the sides' level, not the actual level.
    It's not really a problem, though, so I'm not inclined to put much effort into figuring out exactly how it happened.
  4. #34
    Aug 2011
    Massachusetts
    LoL...I appreciate your honesty. So from a quick search here the rule of thumb is to keep FC at about 8% of the CYA?
  5. #35
  6. #36
    Quote Originally Posted by Jacob99 View Post
    That will work, most of the time. You can't kill established biofilms (slime, black algae, mustard algae) that way, however.
  7. #37
    Aug 2011
    Massachusetts
    I tested my CYA again today. I think yesterday's results weren't accurate. After reading some more on this site, I guess the CYA should be tested on water at room temperature, but I tested with water immediately out of the pool which was only around 55 degrees. I got a new water sample first thing this morning and just tested it. I also tested outside for lighting purposes. Results today are between 35-40 which is right around my original target.
    However, today my CC crept up from .4 to .8. My water is still pretty darn clear, but maybe I have the start of an algae growth? I haven't been able to brush my walls or vacuum my pool bottom due to the water temps. Pool was installed too early in the season!
    FC: 2.6
    CC: 0.8
    pH: 7.2
    TA: 60
    CYA: 40ish
    Last edited by PoolDoc; 05-06-2012 at 06:16 PM. Reason: Water here at the forum may be "darn clear", but not "d@#$# clear""
  8. #38
    Why can't you vacuum or brush? My water is still cool (haven't measured the temp) and I've been vacuuming for awhile now. Probably the first time was sometime at the end of March and I doubt my water was any warmer than 55 at that point.
    By the way --- to save on your reagents, use the 10ml water sample instead of the 25ml sample. A testing margin of 0.5 is just fine and it isn't worth the extra reagents to get a 0.2 margin.
  9. #39
    Aug 2011
    Massachusetts
    So you actually go into the water to vacuum and brush or you do this from outside the pool?
  10. #40
    I just vac from outside the pool manually or I throw one of my automatic cleaners in. I have a Wanda the Whale and also a Polaris 65. No way I'd go in water that is that cold!
  1. Test results, which do I believe?
    By cjs1970 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 02:05 PM
  2. Please help with test results, etc.
    By meeko350 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2012, 03:28 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Please review test results and advise
    By reneep in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2006, 09:56 AM
  5. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
