Results 1 to 10 of 44
Thread: Test Results - Please Review
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    Default Re: Test Results - Please Review
    Slowly as in a minute or two. As soon as you see the skimmer basket clear, pour some more. Go ahead and use the whole box.
    Sweet. Thanks. Got the stabilizer in, got the liquid chlorine in, and I'm heading out now to put the Borax in. Should I let my pump run on full speed overnight? I still haven't quite figured out when to use the low speed vs. the high speed.
    Wilbar/Sharkline Tahitian 23,900 gallon 30' Round AG, Hayward 1HP 2-speed pump, Hayward 300# Sand Filter, Taylor K2006c.
    If you're pool is cloudy, you'll get better filtration with a cartridge or sand filter on low, than on high.
    Aug 2011
    Massachusetts
    It's looked clear, but right now it's looking a little cloudy since adding the liquid stabilizer. I'm hoping it'll clear up by morning. Should I run it on low overnight?
    Aug 2011
    Massachusetts
    No worries...i did lower it and pump has been running. Gonna go test again in a little bit. I have to say I'm kind of enjoying it so far considering I haven't used the pool yet. Will I get over it? LoL
    Aug 2011
    Massachusetts
    Got my new readings...chlorine low again...damn my lack of stabilizer!
    FC: 1.8
    CC: 0.2
    pH: 8.0 (I really don't understand how this is possible. I was at 7.0 yesterday. I added 1 gallon of liquid stabilizer, 1 gallon of liquid chlorine, and one 76oz box of Borax. According to the pool calculators, I needed 169oz of Borax to raise my level to 7.4. I used less than half of that because that's all I had on hand, and it raised it to 8.0. Very strange. So one drop of the R005 turned it to the desired color of pH, so I will need 22oz of Muriatic acid to get back down to a 7.5 pH reading. (I think)
    TA: 50 (the Taylor kit says it'll turn from green to red, but it's more of a pink, right?)
    CYA: I didn't even notice that the lowest level on the tube is 30, and I already knew I would only have around 15 so I guess I just wasted my drops. Oh well, won't be doing that again. I have some HTH stabilizer that I'll be putting in over the next couple of days to raise up my CYA.
    I guess I'm just concerned with the pH. Did I do something wrong?
    Edit: I just checked and I have no idea where I got 169oz from? I guess I should double check my numbers before adding chemicals. Regardless, to get from 7.0 to 7.5 it says I needed 95oz of Borax and I only put 76oz, so I still don't understand how I got from 7.0 to 8.0.
    I'm about at the point of encouraging people to ignore the "add this much, to get X change in pH" part of the PoolCalcultor. In my opinion, it causes more trouble than it's worth. It's much better simply to add a basic dose, wait, and the recheck the pH.
    Or, if you REALLY just have to single-shot the pH adjustment, you can use the acid or base demand tables in the K2006. I guess, if there's enough demand, we could cobble together a basic borax addition table for that test.
    Here's general rule: simple calculated doses to change pH by 0.X pH units are NOT reliable. Just use a basic dose (1/2 box borax; 1/4 gallon of muriatic) on your pool, when you need to make a change. Add, wait, retest -- and repeat if needed!
    But, in this case, adding too much borax is not bad. Having a 50+ ppm borates residual will make your pool somewhat more resistant to algae, and your water a bit more 'sparkle-y'. A LOT of people do this deliberately.
    Do you have a Sams Club in your area? If you do, you might want to make a run, and pick up 50# of "PoolBrand Chlorinating Granules" for $105. (That's what it costs, in Chattanooga, anyhow.) Using it will
    1. raise your chlorine
    2. raise your stabilizer
    3. lower your pH.
    You probably won't be want to use it exclusively -- if you do, and use it all up this season, you'll end up with a CYA level near 130 ppm. You can do that, but you have to make some modifications. But, it would get you into range very quickly right now, and make the next month, very easy. After that, you'll have to switch to using bleach or cal hypo some of the time, instead of just dichlor.
    Do NOT buy dichlor from Walmart or Costco -- they've 'gone over to the dark side' and are selling hodge-podge dichlor + mystery goo blends. Locations like Lowes, Home Depot or Ace Hardware may have the plain dichlor OR they may have the pool version of chemical hobo soup. If you try to buy there, may sure you can read the chemical labels correctly. Otherwise, if you want a smaller quantity, you can get it from Amazon:
    Kem-Tek Dichlor 12lbs
    Kem-Tek Dichlor 22.5lbs
    If you buy the 12lb size, you'll have 36 ppm stabilizer in your pool when it's gone. With the 22lb size, you'll have about 66 ppm.
