I drained quite a bit of water then added fresh water. Still showing orange. Should i turn the filter on without the chlorinator.
18x36 3.5 - 8' depth, IG pool with SWCG; ~21K gal
If your pool is green, let it chlorinate.
Ok, did the dilution test eith my OTO. Took it down to a third and was still a tad darker yellow then my test would read.
Is it still green?
I would say the pool is more cloudy then green. If you sweep it then green does appear to come off the vinyl and then the pool looks nasty. Buying the test you all recommended today. Sure I wont have it until next week because of shipping. I am going to use my Wal-mart test again this evening when I get home.
Add the bleach this evening, and then sweep AFTER you've done so; not before.
You got it PoolDoc. Thanks so much for your help. I will report back. Just signed up for the year. Looks like I will be here a long time.
