Results 1 to 10 of 49
Thread: greenish and cloudy
    Default Re: greenish and cloudy
    Orange is probably about 20ppm chlorine which is pretty high. I just skimmed back over your thread but didn't see a CYA reading. Do you have one?
    EDIT -- Ganny --- read the Best Guess Chlorine Chart in my signature below.
    May 2012
    Florida
    Thanks Watermom. I dont have my good test im yet. All i can check is chl and ph. I did the 1/2 dilluted with tap water and it came out yellow. Slightly darker then the test had.
    18x36 3.5 - 8' depth, IG pool with SWCG; ~21K gal
