Results 1 to 10 of 36
Thread: Chlorine level is low
    May 2012
    South Carolina
    Default Chlorine level is low
    Hi I'm new to this method. I'm tired of driving 20 miles to the pool store every other day and I've already spent $200 on chemicals that still have not completely cleared my pool. I have been reading a lot of the posts on here the past week so I thought I'd give it a try. I bought a DPD test kit from Leslies. My pH is 7.8. My chlorine was zero I guess. I put 2 gallons of bleach in Saturday evening and checked chlorine Sunday... still zero. I added another gallon of bleach Sunday evening and checked it Monday...still zero. Added 2 more gallons Tuesday evening and checked it today it was .5 so I thought I might have a bad kit...so I added a 1 pound bag of shock (Trichloro-s-triazinetrione* Available chlorine 48.6%) and finally saw some color on the test! The test only goes up to 5 and the color was darker than that. So did I mess up by adding the shock? What should I do next?
    Default Re: Chlorine level is low
    Hi Sherrie and welcome to the Pool Forum!
    You didn't do anything by adding the shock as long as the shock is not a trichlor blend that has copper in it.
    To be able to give better advice, we need to know more about your pool -- type, size, type of filter, size of pump. How does the water look? Can you post a complete set of numbers taken with your kit? We recommend buying a DPD-FAS kit (Taylor K-2006) but since you already bought the DPD kit, you can just pick up a K-1515 from the test kit link in my signature below and it will give you the test that your kit is missing which allows you to measure chlorine levels higher than 5.
    Post the requested info and somebody here should be able to help you.
    May 2012
    South Carolina
    Ok I ordered the K-1515 kit but I wont be getting it for about a week. I have an above ground 18x52 round pool with a Heyward sand filter that says 50 pounds and a 1 HP Heyward pump. My pH is still reading 7.8 but the chlorine reading is clear so I guess its zero. The water is a little cloudy and there is still a little algae on bottom. What should I do until I get that other test kit?
    May 2012
    South Carolina
    Well I guess I have to get another test kit. The kit I have from Leslies is "Basic Poolcare DPD Test Kit" Free Chlorine or Bromine,pH and I ordered the k-1515 today so now my question is what other kits am I gonna need before I can do anything else?
    Quote Originally Posted by sherriemoseley View Post
    Here's the Leslie's page: http://www.lesliespool.com/Home/Pool...Test-Kits.html
    Tell me exactly which kit you have (none there are called "Basic Poolcare DPD").
    Apr 2012
    Texas
    Hi sherrie,
    In the meantime just continue adding the 1-2 gallons of bleach every night. You don't want to let your chlorine be at 0 at any point right now because of the algae already present
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
