Results 1 to 10 of 36
Thread: Chlorine level is low
    May 2012
    South Carolina
    Default Re: Chlorine level is low
    Okay I have continued to add a gallon of bleach every evening and I just received my k-1515 kit today. I just ordered the k2006 so in the meantime can I use the kits I have? Also I'm a little confused on the k1515 because it says: For 1 drop=0.2 ppm,use 25 mL sample or For 1 drop=0.5 ppm,use 10 mL sample.So which one do I need to use 10 mL or 25 mL? I am off work tomorrow and would like to do your recommendation tonight and tomorrow AM. I already posted my pool info on this thread 5-4-12. As far as the list of chemicals I've put in since opening, I reeally cant give you the names of any of it because I used it all as instructed by Leisure Depot and no longer have the containers. I know we did pH increaser and a flocculant and I had to vacuum algae to waste,then Calcium Plus which I still have some left and the brand name is Sparco and lots of shock which I think the brand name was Pool Life, maybe?
    Use the 10ml sample line. That way, you add the DPD, then count the drops of FAS solution till it turns clear. (Swirl after each drop!) Multiply the drop count x 0.5 and that's your ppm reading.
    Post your test results, once you have them.
    Quote Originally Posted by sherriemoseley View Post
    If you'll make a signature line with all the pool info, it makes it easier for us to help. That way, we don't have to keep scrolling back up through a thread to find it. You can use the link in my signature below to help you do it.
    May 2012
    South Carolina
    Ok I think I did the signature line right. Thanks! Just tested pool then added 1 gallon bleach and retested. Will test again tomorrow morning and evening and post all readings then.
    18' round 7.7K gal AG vinyl pool; Bleach; Hayward S144T sand filter; Hayward 1HP pump; hrs; Taylor K-2006; City; summer: ; winter: ; ; PF:16
    Yep, you did it right. Add the volume, too. Then it should be good to go!
    A question --- do you have a 50 lb. sand filter?
    May 2012
    South Carolina
    All we could find on the filter was 50 lb. so I think so. I know after reading everyone elses posts I have a small filter and a huge pump. Of course thats what the pool store sold us with the pool. Here are my readings for the past 2 days.
    -- 5-10-12 Thursday 10:45 pm -- pH 7.2 - FC 10.5 - CC 1 -- Added 1 gallon of regular bleach
    -- 5-10-12 Thursday 11:00 pm -- pH 7.5 - FC 44.5 - CC 1.5
    -- 5-11-12 Friday 8:00 am -- pH 7.5 - FC 24 - CC 1
    -- 5-12-12 Saturday 6:30 am -- pH 7.2 - FC 9.5 - CC 1
    No algae present now. We can see the bottom but the water is still a little cloudy. Still waiting for k2006 kit. What next?
    Any idea when you'll get the kit? We really need to know a CYA level. Keep you chlorine up, run the pump 24/7. Is your filter pressure rising? Backwash whenever it rises 8-10 psi over clean filter pressure.
    If it truly is a 50lb filter, you're not kidding that you have a huge equipment mismatch! It may take a LONG time for your pool to clear.
    I'm gonna ask Ben to pop back in here and advise you again. Especially with such a big equipment mismatch.
    Hi Sherrie;
    Watermom is right -- we really can't tell much without knowing more about your pump and filter. The marketing games with those are so deceitful, we have a REALLY hard time figuring out what's going on.
    Is your filter like either of these?
    If you can get exact make and model numbers, it would help. It may be, you have a tiny filter with a tiny pump . . . and a deceptive label -- that's not good, but at least the pump won't blow the dirt through the filter. But, if you have a REAL 1 HP pump, with a 50# filter, it's going to take some hardware corrections to get your pool clear.
