Re: Another cloudy water thread...can't seem to fix it
Sounds like you're there, 0.5 ppm is within the error of the 10ml sample test. Sounds like adding DE is the next logical step; be sure to check if it's blowing out the returns when you add it. BTW I haven't used the cellulose product you mentioned but I did try another last year and found that it didn't help and when I opened the filter I found it in large gray clumps on the sand.
