Thread: Pressure gauge bad?
    Jun 2011
    Default Pressure gauge bad?
    So, I just opened up the pool this year and I think my pressure gauge is not working right. When the pump is off, it's reading 30psi. After I cut on the pump, it reads 44psi. Is there any way to tell if it's bad or should I just remove it and go buy a new one?
    Eric
    Steel-sided, 7,186 gallon Above Ground Pool
    Hayward 150 lb sand filter
    Hayward Power-Flo LX Pump (1.5hp | 70 GPM)
    Taylor K-2006 test kit
    Default Re: Pressure gauge bad?
    If it's not going to zero with the pump off, you're better off replacing it. It only takes getting wet and cold once to make them malfunction, and they're fairly inexpensive. I end up replacing mine every year.
    Jun 2011
    Janet, do you buy a replacement at a pool shop or Sears?
    Walmart if they have them in stock, local pool store or online if not.
  1. Pressure gauge failure?
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 06-01-2011, 10:33 AM
  2. Broken Pressure Gauge
    By fog80 in forum Pool Equipment & Operations
    Last Post: 05-25-2011, 05:22 PM
  3. SP710 pressure gauge
    By cantileveredge in forum Pool Equipment & Operations
    Last Post: 09-04-2007, 09:17 PM
  4. pressure gauge/motor shutting off
    By pluck in forum Pool Equipment & Operations
    Last Post: 07-19-2006, 10:08 PM
  5. changing out pressure gauge
    By bbluvbasket in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 12:24 PM
