Thread: Chemical substitutes?
    May 2012
    North Carolina
    Default Chemical substitutes?
    Hi, I was wondering if other chemicals can be used in place of the expensive ones?
    Default Re: Chemical substitutes?
    That pretty much sums up what we are all about! Do a lot of reading on the forum and on our sister website poolsolutions.com and I think you'll find the answer to that question! Welcome to the Pool Forum!
    Tina;
    I'm guessing your concern isn't expensive chemicals exactly, but rather the over all cost of operating a pool?
    That's an important distinction, because I can run a pool MUCH more cheaply, using "expensive chemicals" than most pool owners can using "cheap chemicals". In other words, how, and what, you do in managing your pool matters more than the cost of chemicals per pound.
    Also, some things, like cleaning up a slimy pool are expensive no matter how you do it, unless you can drain and refill cheaply.
  1. Chemical Help
    By mreesept in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2012, 01:58 PM
  2. Need Chemical Advice
    By vvon66 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2012, 10:36 PM
  3. Chemical Age
    By mohawk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2008, 09:02 PM
  4. CYA: Chemical OR Organic
    By stma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2008, 04:44 PM
  5. PH Testing Chemical
    By jrv331 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2008, 08:23 PM
