Results 1 to 10 of 66
Thread: starting up after winter
    Jun 2011
    Oklahoma
    Default Re: starting up after winter
    Should I be adding Stabilizer to keep chlorine in?
    20' x 48" Intex round Ultra AGP ~8800 gallons -- Intex krystal clear 635t 1500gph; PF: 13
    BigDave's Avatar
    We don't know if you have any CYA, you probably don't but until you get the refill...
    Do test and add chlorine as often as possible so it doesn't go low.
    Jun 2011
    Oklahoma
    Ok so the water is now milky blue before brushing, but after brushing turns greenish/brownsih until everything settles. Is the algae dead?? I still have the oto kit. Will it actually turn orange if my chlorine is high enough?
    I don't think it is all dead yet from what you are describing but it is hard to tell what is going on without testing numbers. Really high chlorine will turn an OTO chlorine test orange.
    Jun 2011
    Oklahoma
    what test numbers do you need?
    We really need a CYA reading since necessary chlorine levels are based on it. Do you have one?
    Jun 2011
    Oklahoma
    Unfortunately not. I ordered a replacement bottle and the shipping estimate is Thursday May 17, 2012 - Tuesday May 22, 2012
