Thread: Pentair CCP420sq ft Filter Question
    May 2012
    Gulfport, MS
    Default Pentair CCP420sq ft Filter Question
    I am about to pull the trigger on a 33'x54" AG pool. I want to go with a cartridge filter. Will the pentair 420 sq ft filter system do the job? Can I go smaller? Thanks for any help. Below is a link to the filter.
    http://www.pentairpool.com/pool-pro/...filters-27.htm
    Default Re: Pentair CCP420sq ft Filter Question
    Let's work this out the right way.
    33' x 54" pool => actual water volume = 15.5^2 * pi * 4 * 7.48 = 22,600 gallons (at the 48" water line)
    6 hour turn over rate = 22,600 / 6 / 60 = 63 gpm; 8 hour turn over rate = 22,600 / 8 / 60 = 47 gpm;
    Target flow => 60 GPM on HIGH
    Commercial cartridge filter rates = 0.375 gpm / sft ; Required sft for pool => 60/0.375 = 160 sft
    So the 175 sft Hayward would be fine:
    http://www.a1poolparts.com/-strse-25...dge/Detail.bok
    as would the 200 sft Pentair
    http://www.a1poolparts.com/-strse-14...ear/Detail.bok
    ============== Not finished - I'll try to get back to this ===============
  1. Pentair de filter
    By extexan in forum Pool Equipment & Operations
    Last Post: 11-04-2011, 07:03 PM
  2. Pentair Intelliflo 4x160 Question.
    By ts8181 in forum Pool Equipment & Operations
    Last Post: 08-29-2011, 02:43 PM
  3. Question on installing Pentair Cartridge Filter - ABS or PVC?
    By sardelli in forum Pool Equipment & Operations
    Last Post: 06-07-2011, 10:25 AM
  4. Pentair Intellitouch Question
    By iwannapool in forum Pool Equipment & Operations
    Last Post: 05-22-2007, 03:24 PM
  5. Pentair Heat Pump Question
    By RENOPOOL in forum Pool Equipment & Operations
    Last Post: 05-26-2006, 11:41 AM
