Another possibility might be ground water seeping in through the bottom drain. If the ground water runs through a sulfur vein it certainly would carry a bad smell. Bleach and more bleach.
Possible, I suppose, but only if the main drain line is cracked. Normally if that's the case, you'll have a pretty serious leak when the ground is dry.
We do not fill from a well but instead from city water. We will start to bring up the fc ppm to 20 and will also open up the filter. Is there a trick to opening the filter we have never done it before.
I hope we done have a main drain leak. We have had lots of rain so I will wait for a dry spell but not sure where I would check the ground to be damp. Any thoughts here would be appreciate.
I will share results once we start to get chlori e up.
Thanks all for the insight!
In-ground vinyl rectangle
18'x36' rectangle 27.5K gal IG pool; Salt generator; Haward sand filter; pump; 24hrs; Taylor kit you recommended; utility water; summer: ; winter: ; iPhone; PF:4.4
Yes. Tell us the exact make / model, or send pictures to [email protected].
