Results 1 to 10 of 12
Thread: Stinky Water - My Pool Smells Like Poop
    Jun 2011
    Des Moines, IA
    Default Re: Stinky Water
    We do not fill from a well but instead from city water. We will start to bring up the fc ppm to 20 and will also open up the filter. Is there a trick to opening the filter we have never done it before.
    I hope we done have a main drain leak. We have had lots of rain so I will wait for a dry spell but not sure where I would check the ground to be damp. Any thoughts here would be appreciate.
    I will share results once we start to get chlori e up.
    Thanks all for the insight!
    In-ground vinyl rectangle
    18'x36' rectangle 27.5K gal IG pool; Salt generator; Haward sand filter; pump; 24hrs; Taylor kit you recommended; utility water; summer: ; winter: ; iPhone; PF:4.4
    Quote Originally Posted by AngelaGarciaG View Post
    Yes. Tell us the exact make / model, or send pictures to [email protected].
