Results 1 to 10 of 35
Thread: Extremely cloudy green water.
    May 2012
    Huntington, WV
    Default Re: Extremely cloudy green water.
    Ok, the kit came in today. I have a quick question first though. Should we turn the pump on to circulate the water to get a more accurate test or let it settle first?
    24' round AGP, ~13K gal, Hayward S180T filter, Hayward 1.5 hp Power-Flo LX pump
    Let it run for a few minutes before collecting a water sample.
    May 2012
    Huntington, WV
    pH - 7
    FC - 24 (Woah)
    CC - 2
    TC - 26
    Alk - 150
    CYA - 60-70
    Yeah, that is some pretty high chlorine! A pH test is inaccurate when chlorine is that high. With a K-2006, it should be accurate when the chlorine drops below 15ppm. Retest it when your chlorine drops.
    FYI for anybody else reading this thread, pH is not accurate when chlorine is above 5ppm for other kits.
    May 2012
    Huntington, WV
    We haven't added any chlorine at all since Tuesday and every test we did (before we got the 2006 kit today) showed the level never lightened up at all. It's stayed consistently the same color since then. Anything we can do to drop chlorine levels quickly?
    But, what does it look and smell like? And, were you able to vacuum the sediment off the bottom successfully?
    May 2012
    Huntington, WV
    It actually smells really clean. We left the pump off a few days to let everything settle and the water was cloudy, but not nearly as dirty or green. We didn't vacuum anything yet because we wanted to test everything first. Should we leave the pump off overnight and vacuum it then test again? At what point do we use the flock? After all levels are right or before?
    Best way to lower it? Go swimming!
    Seriously, even when the sun doesn't take it out, body goo will! And, 26 ppm is NOT too high to swim in with CYA > 50 ppm.
    Just to be safe though - wear last year's swim suits! Chlorine is much harder on Lycra, than people.
    May 2012
    Huntington, WV
    Should we use the GLB Drop N Vac now then? I mean, the algae has to all be dead. I'm pretty sure i've even seen birds dropping out of the sky from 100 yards away. Haha. Not really, but seriously, my neighbor's house is 40 yards from mine and he can smell the chlorine from his driveway. Is it better to get our levels right before we use the Drop N Vac or should we use it now, vacuum all the gunk out of the bottom and then test our levels?
