Thread: Working on building a pool looking at a Pentair system
    May 2012
    Default Working on building a pool looking at a Pentair system
    Looking at a pentair variable speed pump and SWG. With a sand filter, what controller should I use?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Working on building a pool looking at a pent air system
    I would stick with a Pentair controller as that will give you the most flexibility in controlling the pump plus if you have three major Pentair items (pump, controller & filter), you can get an extended warranty. Check out the features and price points of the Intellitouch and Easytouch to see which would work better for you. Both have a version with an SWG add on and both are fairly feature rich but the Intellitouch has a lot more features at a higher price point.
    http://www.pentairpool.com/pool-owne...systems-49.htm
    http://www.pentairpool.com/pool-owne...systems-79.htm
    Mark
  1. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
  2. Finaly got my Salt system working
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 02-13-2012, 07:41 PM
  3. Connecting Pentair MobileTouch2 to i5 system
    By KnightsArmy in forum Pool Equipment & Operations
    Last Post: 06-26-2011, 09:07 PM
  4. Paramount system not working right
    By kluczenk in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-27-2010, 06:48 PM
  5. Aquarite vs Pentair Intellichlor IC40. For Intellitouch system
    By hulla in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-12-2006, 07:14 PM
