Looking at a pentair variable speed pump and SWG. With a sand filter, what controller should I use?
Not really my area, but I'm pretty sure that the controllers are not specific to filter types.
PoolDoc / Ben
I would stick with a Pentair controller as that will give you the most flexibility in controlling the pump plus if you have three major Pentair items (pump, controller & filter), you can get an extended warranty. Check out the features and price points of the Intellitouch and Easytouch to see which would work better for you. Both have a version with an SWG add on and both are fairly feature rich but the Intellitouch has a lot more features at a higher price point.
http://www.pentairpool.com/pool-owne...systems-49.htm
http://www.pentairpool.com/pool-owne...systems-79.htm
Mark
