Thread: Past experience with National Pool epoxy paint? Advice for novice DIY painter?
    Default Past experience with National Pool epoxy paint? Advice for novice DIY painter?
    I need to put a coat or two of paint on my pool this spring. Has anyone used http://www.nationalpoolfinishes.com/ paint before?
    Any brands to stay away from? Any brands that have worked well for people in the past?
    So for I have gathered that prep work is key and that I will be using epoxy paint because that is what is currently on the pool.
    Any and all advice is greatly appreciated.
    Default Re: Past experience with National Pool epoxy paint? Advice for novice DIY painter?
    Epoxy is very finicky -- not hard, but finicky. I've used Kelley Tech epoxies successfully many times - usually Zeron + Gunzite or Poxoprime. But, I've seen a LOT of epoxy failures. My recommendation is to use Kelley's products and to read their application bulletins CAREFULLY.
