Re: Will this work?
Thanks for the reply!!
-Yes, I have 9lbs of burnout left. The active ingredient is calcium hypochlorite-57.8%, and "other" is 42.2% not specific though.
-Pool is still cloudy "blue-green" I can see about 4'-5' deep. Not foamy anymore, but haven't shocked in 2 days
-Pump is running, will clean steps and get the products you recommend tonight.
-Nothing connected between pump and filter
-No access to Sam's Club
Also, I have a different pool store in walking distance from my house. Can I trust their testing method, or should I still pick up a OTO test kit? They use "PINPOINT" Computerized Water Analysis.
-Temp= 75
-PH= 7.0
-Alkalinity= 90
-CYA= 40
Thank you!!
Correction-my pool is 22,500 gallons not 29,000
18'x32' rectangle 22.5K gal IG vinyl pool; cal hypo through skimmer; Tagelus TA-60/60D sand filter; Hayward 3/4HP uprate Super Pump pump; 24hrs; Taylor K-2006; utility water; summer: none; winter: mesh; ; PF:5.3
