Results 1 to 9 of 9
Thread: Need help new pool owner
    Default Re: Need help new pool owner
    A few questions for you.
    What kit did you buy? Can you explain how you performed the test? How often are you shocking the pool? What time of day are you adding chlorine?
    It sometimes takes awhile to clear a pool up but the more consistently you can keep your chlorine at shock level, the faster it will go. Every time you test, add enough bleach to get back up to 15ppm.
    The fact that your pool is so cloudy and your chlorine is disappearing so fast means you are still fighting something in the water.
    May 2012
    MI
    Ok thanks that makes tons of sense I take my water to local pool store they are right down the road and don't charge me, I will try to keep adding shock and bleach until it clears up, I am also using liquid shock is this best?, the lady at the shop says it works better.
    The type of chlorine you use doesn't really matter but bleach or liquid chlorine add the fewest other things to the water which is good.
    Quote Originally Posted by monsmth123 View Post
    Ok thanks that makes tons of sense I take my water to local pool store they are right down the road and don't charge me.
    Hi Monsmith;
    I'm not sure if you were being sarcastic, or not. Regardless, the idea that pool stores "don't charge you to test your water" is one of the most effective marketing lies in the US.
    I wish I had posted a history of the development of computerized pool testing, when I started PoolSolutions in the late 90's. At that time, the guys I knew who'd watched it happen were still alive. Unfortunately, that's no longer true, and my notes aren't great. But here's the Cliff Notes' version: in the late 70's and early 80's, swimming pool chemical companies introduced "computerized water testing" PURELY as a marketing tool!
    I saw one of the early pool computers installed -- it was a "mini-computer" that cost over $10,000 in 1980 dollars! There's no way that that store, or any other store of the time, would spend that sort of money merely to help pool owners. The ENTIRE purpose of those systems was to utilize the 'cachet' of "computerized water analysis" to sell you more chemicals, and especially, more of the high margin chemicals.
    Here's a basic fact you need to always remember: accurate and reliable water testing and analysis HURTS pool store chemicals sales. In other words, if they do it RIGHT, they lose money. If they do it WRONG, but don't get caught, they make money!
    Not all pool store owners understand this -- and the pool chemical companies don't explain that their water analysis programs work best, when they make random mistakes. But, for years, we've had pool owners who lived nearby each other collect multiple samples from the SAME pool, and then have them tested as if they were from DIFFERENT pools. As best I can recollect, it has NEVER happened that a pool store got the same results from all three samples, much less recognized (from the numbers) that they were all from the same pool!
    So, whatever else pool store water analysis is, it's NOT free. Rather, it's very, very expensive.
