Results 1 to 10 of 11
Thread: Best Way to Add CYA
    Jun 2011
    Franklin, TN
    Default Best Way to Add CYA
    What's the best way to add granular CYA to the pool? I tried the old sock method I read about somewhere on the Forum, but didn't work very well. I'm sure it was user error. I am now trying to dissolve the granules in a bucket of water before putting them in the pool, but they don't want to dissolve. Any advice?
    -Andrew
    Pool Specs: 20,000 gal. • inground • vinyl liner • Hayward s200 sand filter
    21' kidney 20K gal AG pool; Bleach; Hayward S200 sand filter; Hayward pump; 8/10/2012hrs; Taylor k2600; utility water; summer: ; winter: ; iPhone; PF:6
    Default Re: Best Way to Add CYA
    Easiest way to add CYA with a sand filter (assuming you are not clearing a green pool at the same time).
    1. Backwash your filter first since you can't backwash for a week
    2. SLOWLY pour the desired amount of CYA granules direcly into the skimmer WITH THE PUMP AND FILTER RUNNING. (The CYA will get caught in the filter where it slowly dissolves).
    3. Run the pump and filter continuously for the next 24-48 hours to help the CYA dissolve faster (Optonal but a good idea.)
    4. DO NOT BACKWASH FOR THE NEXT WEEK.
    5. Test the CYA level in a week (It will probably all dissolve before that but this way you KNOW you won't be adding more than you need if it tests low!)
    To Summerize: Add it to the skimmer with pump running, don't backwash for a week, forget about it for a week, Test it in a week and add more if still too low!
    Jun 2011
    Franklin, TN
    Thought that might be the trick, but wasn't sure. And, no green water. Luckily my water is crystal clear this year since I had to have the pool drained to fix a leak. Just working to get everything reintroduced and balanced back out. Thanks Waterbear.
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    I'm clearing a green pool and need to add cya. Pantyhose method?
    The water is to the point where I can almost see the bottom, but I haven't turned the filter on yet. I need some time to clean the de "fingers" and prepare to back wash like every hour.
    I'd clear up the pool and then add CYA if it were my pool. If your pump/filter are not yet running, you're not really going to be able to get it dissolved and into the water.
    Glad to see you back around the forum for another season!
    Thanks. Got the filter going now, FC is holding....I'll vacuum up and then add cya
    20,000 gal IG plaster, Hayward Super Pump, EC65 DE filter.
