Results 1 to 10 of 19
Thread: DE leaks into pool; and filter clamp leaks elsewhere
    Default Re: DE leaks into pool after filter turns off
    Quote Originally Posted by Lowdown View Post
    Shouldn't there be a "if we don't fix it you don't pay" deal, or is that just wishful thinking?.
    I didn't do that, when I did hourly service work -- it still took my time to get there; my tools and knowledge to check it out, and it wasn't my fault it was broken.
    Oct 2011
    Riverside, California
    Update: got a pool company to replace clamp through our home warranty and no more leak. So I don't need a new filter
    Great! Thanks for coming back with an update for us!
    Just to make sure I understand: they replaced the entire clamp on the filter, and that fixed the problem?
    Oct 2011
    Yes the old metal clamp that has 2 bolts to tighten the clamp has been replaced with a new plastic clamp with 1 bolt that tightens the clamp, and no more leak
    Thanks for the info!
    Oct 2011
    Thanks for your help
  1. Jacuzzi cfr-100 pool filter leaks
    By Chuckcowan in forum --cleanup--
    Last Post: 10-02-2012, 09:37 PM
  2. DE leaks into pool after filter turns off
    By Jimmya in forum Pool Equipment & Operations
    Last Post: 05-08-2012, 11:52 AM
  3. Several Leaks Around Filter System
    By klwlls11 in forum In-Ground Pool Construction and Repair
    Last Post: 05-06-2011, 09:47 PM
  4. Leaks in DE filter
    By Mom2Czars in forum Above-Ground Pool Construction & Repair
    Last Post: 07-13-2007, 10:37 AM
  5. Pump and Filter leaks
    By Wolffe in forum Pool Equipment & Operations
    Last Post: 05-15-2007, 10:21 PM
