Re: Struggling to get water clear
Chemical test results:
FC - .4ppm
CC - .6ppm
pH - 7.2
Total Alkalinity - 50 ppm
Calcium Hardness - 270ppm
Pump - Challenger PacFab2. *Will send photo of sticker with stats. Not sure it has detail that helps.*
Filter - Nautilus FNS48. *Will send photo.*
Plumbing - lots of galv pipe visible in pump house as well as PVC. There are two PVC pipes in pool pulling water to filter. *One goes into deep end and is on the wall under diving board. *Is this called a main drain? *The other is on the side wall about half way between shallow and deep end of pool. Its intake is about 12" under surface and it can be swiveled up. The vacuum attaches to this one. *There are two stainless pipes with water flowing into pool (called returns?). *These were pouring/splashing into pool so I added a rubber elbow*and a PVC piece with elbow to each so water flows into pool in a clockwise pattern. This has helped the circular flow of surface water.*
Pool - concrete/gunnite. I believe it was built in the 50s. No skimmers and it has a gutter that runs around the perimeter in the vertical wall above the water line. This gutter has drains for overflow that go to street.*
Let me know what other details on pool are needed. And a tremendous thanks for the website and any guidance. We're excited about the pool and I'm thrilled not,to be under the thumb of a pool service guy.*
Pool: 40K gal, 20' x 50', 8' deep - In-ground / Concrete w/ Zeron epoxy paint ● Pump: Hayward Super Pump (2HP) ● DE Filter: Nautilus FNS - 48 ft^2 ● Valve: Pentair SM-20-2; SWG: Pool Pilot with CC-15 cell
