Hello all,
I have a 15,000 gallon in ground pool that I opened 3 weeks ago. Holy swamp!!! I have been a longterm lurker at this forum (as in years) and follow the BBB method. I raised my CL to 20 and it 3 days had sky-blue but extremely cloudy water. I couldn't see the first step. I held the Cl and let the filter go for about a week . Now I could see the 1st step but no others. I took apart the filter, and it checked out....I flushed it with a hose and put back together. Sand was replaced last year. I have let the filter run 24/7 for the past 2 weeks while maintaining a free cl of 20. The water is not budging. It is extremely cloudy. For the past week I have been adding about a cup of slurried DE to through the skimmer with minimal results.
The pool is holding CL level overnight, so I think that all the algae is dead.
Current test results
CYA 40
Total cl 20
combined cl 20
ph 7.9
Alk 125
Borates are 15 but are from pool store test, as I don't have a borate test.
I have a SWG but have left it off during this process. I have a 3/4 hp pump on a tagelus 50 (200lbs sand) filter, so I don't think the pump is oversized, but I may be wrong! Is there anything else I can do to speed the process??
Thanks!!!
