Results 1 to 10 of 14
Thread: Ph and alkalinity low, should I wait to adjust
    May 2012
    Ohio
    Default Ph and alkalinity low, should I wait to adjust
    Vinyl liner, ph 7.0, alkalinity 60, chlorine 8.0, I don't know what cya is or how to test for it. Anyways, every year, my alkalinity goes off the charts >240 and I can never get it back down...even hired someone and they couldn't do it either. Even tried some fountain methods...losing battle. My water here has high alkalinity and since I am vacuuming to waste 2X a day and replenishing the water, can I wait until I get the process of vacuuming to waste is over and then test my levels after all that new water is in and adjust or will killing off the algae not work unless it is adjusted? I've never had alkalinity anywhere near in the normal range, so starting this year off low has me a little excited that it might be normal for once, but I don't want to screw it up with raising now with all the new water that I know will raise it, but at the same time, it is pointless to not adjust now if I can't get rid of the algae. I think it is working as the pool started off black(okay, maybe dark dark green with about 5000 tadpoles and 200 frogs) and it is now a milky blue color after 3 days....woot. Also, any suggestions of how to keep alkalinity perfect once I get it there? Thanks.
    Default Re: Ph and alkalinity low, should I wait to adjust
    Let's worry about the alk once the pool is cleared up. Is there still a lot of debris on the bottom that requires vac to waste twice a day? If not, just work on killing the algae and filtering. Keep the chlorine high. CYA is cyanuric acid and is also called stabilizer. It is kind of like sunscreen for your chlorine. Without some in the water, your chlorine will disappear fast especially on a hot sunny day. We really need to know that test result to be able to give good advice since required chlorine levels are based on CYA levels. (See the Best Guess Chlorine Chart in my signature below.
    Your pH needs to be bumped up. You can use some 20 Mule Team Borax (laundry aisle at Walmart) to raise it. Once we know your volume, we can suggest amounts.
    It sounds like you need a good test kit. The one we recommend is the Taylor K-2006 or 2006C. It will test everything you need including CYA. You can get one through the test kit link in my signature.
    We need some more information. What is the volume of the pool, type of filer, size of pump and what all have you put into the pool. (Ingredients, not just "shock.") Then, somebody here can try and help you.
    Welcome to the Pool Forum, by the way!
    EDIT -- Go ahead and read up on lowering alk. There is a link in my signature below about that, too! Also, read the one about using muriatic acid. We"ll guide you through that process after your pool is cleared up.
    Actually, I haven't added that link yet Watermom: it's still here:
    http://www.poolsolutions.com/gd/lowe...p-by-step.html
    May 2012
    Ohio
    Hayward pro series sand model s310t....it's big. And the hayward super pump hp2.0 and 2" inch plumbing...I hope this helps. Water temp 72 degrees
    Ph 7.2
    Alk 80
    Chlorine 11
    Cya about 45
    I don't know how to test for anything else(lost directions), but I do have the Taylor and an aqua chem(started buying good tests 2 years ago thanks to this site).
    Anyways, chlorine has been at an 11 for almost 2 days...not dropping even in sun, so it makes me question if I am performing the cya test correctly as I don't know why it isn't dropping. Never had that problem before. I have no clue what was used to open the pool as a pool guy does come and do that while I am not here(I called and he left message saying 6 bags of a powder chlorine and algeacide). I have this every year when opening the pool. Always gets better if I continue to vacuum to waste 2 x a day to get rid of the algae on bottom for about a week. Should I continue that route or does some of his chemicals need to burn off, but I still want to know reasons for chlorine holding so long....after his initial dose of chlorine, those levels stayed for 3.5 days without dropping. I'm sorry, I'm having total opposite problems than usual and have no clue what I am doing.
    If you've oxidized everything, and the pool is cloudy, you won't lose much chlorine from sunlight, since the chlorine no longer has much to do, and since the cloudiness keeps the sun from destroying the chlorine -- it's sticking around.
    I wouldn't worry about it -- you can swim at FC=11 with CYA=45, with NO problems. Just need to get the cloudiness filtered out!
    May 2012
    Ohio
    Well....back to last years problems, so I decided to post a reply here since it already has some of my info. New numbers:
    Water temp 82
    Alkalinity 220
    Ph 8.0
    Chlorine 0
    Cya <10 I performed it twice and once was near 0 and the other about 10..I am not a chemist)
    Anyways, pool was clearing...I could see bottom for days...not crystal clear, but clear. I did add more water over the last week(alkalinity is off charts on my tap water). I did put 2 tablets of trichloro(99.3%) in the skimmer(I don't know if that is a no no). Anyways, I put in muratic acid tonight...my calculations are in the backyard, but I had just enough that it should bring ph down to 7.8). My pool is about 25,000 gallons and I just put in 5 gallons of 12.5% liquid chlorine and I waited about 10 minutes in the dark(no sunlight) and chlorine level is 0. Grrrr...it was nice last week when my chlorine level held for days and now ??? I can no longer see the bottom of the pool....what am I doing wrong. I feel like I just went from one extreme to the complete opposite overnight and I don't know what I did wrong.
