3rd summer with our pool. Learning as I go... Hence the name.
Multiple questions, and looking for suggestions/opinions on issue below.
I currently have a cartridge filter system. This spring I opened the pool to thick green algae. The pool service I use told me to clean the filters 1-2x daily until the water was clear. I've done this by hosing filters thoroughly, and soaking in bleach water. but it has been getting worse.
Q1) Is there a better way to wash filters? should I let them dry before retuning to the system?
After much frustration and little progress, (Shocking with heavy chlorine has helped, but water stil not moving through filters.) and sending the filters to my pool servicer for a deep clean, they contacted me and "Strongly" encouraged me to swith to a sand filter system. I am hestitent to do this because of the cost, but also because my cartridge system is 2 years old and it seems that the jusry is still out on which is better. Sand or Cart. I know they are partial to this system, but being a novice, it is hard to know which way to go. especially looking at this added investment.
Q2) Should I make the investment ($1300 installed), and go Sand? or should i fight through the rough patch of initial cleaning (system has worked well past 2 yrs when heavy Algae was not present from warm spring.)
Q3) I have also seen a bit of talk around "doubling up"Sand filter feeding into a Cart. filter for the best of both worlds. Is this adviseable? Can it Be done? Cost should be the same as I already have the Cart. Filter syst.
Any input is greatly appreciated... And I hope Ben lets me out of Pool Forum Purgatory so I can learn and participate more in this area.
