Like the title says, about how much borax should I add to raise the pH of my pool to the 'ideal' level? And whats the method, broadcasting or through the filter?
24' Round 52" (44"/12450gal) Deep Namco Morada - ClearWater 22" Sand Filter - 1.5HP (SPL) Speck Pump - Taylor K-2006C Test Kit
Is 52" the height of the pool wall or the functional depth of the water?
What is your TA?
I'm willing to bet that 52" is the wall height and the water level is more like 4.5 feet. I'd suggest adding a third of a box of Borax slowly to the skimmer while the pump is running, breaking up any clumps. Wait 3 hours or so and retest to see where that takes your pH. Then you can decide if you need to add more.
Mastamoon,
Here is a pretty handy link to an online pool calculator that I found in a thread on this forum somewhere (I think). It's helpful in getting an idea of how much to add. Most importantly, don't just throw the whole amount in...its not 100% accurate but it gets you damn close. Add some (half?) and then retest before adding more, if needed. Just like Watermom said above.
http://poolcalculator.com/
I hope this helps!
JP
22500gal IG 22x36 lagoon w vinyl liner -- 1.0HP 2 speed Hayward Superpump -- Intermatic P1353ME digital pump control / timer -- Hayward S244S sand filter -- New Water W400 in-line Auto Chlorinator -- Polaris 9400 robotic pool cleaner
Here is the calculator that most of us use that was created by one of our former members. Although it is called the bleach calculator, it is actually much more than that. You can click on the upper left corner for additional calculators. Hope this helps.
http://www.poolforum.com/zxq/BleachCalc262.exe
Those of us using operating systems other than Windows aren't able to open .exe files since that's a Windows program.
