Results 1 to 9 of 9
Thread: Eyeball looks where?
    JJ in Tx is offline ** No working email address ** JJ in Tx 0
    Spring, Texas
    Default Re: Eyeball looks where?
    yes!
    you want them pointing in the same direction so they are working together not against one another.
    JJ
    Thanks for replies. All of you down-and-to-the-right pointers: don't you find that the whirlpooling water makes the debris on the surface sail past the skimmer, though?
    Spring, Texas
    no problems with the eyeball aimed that way, my skimmer still catches lots of stuff, and the fine stuff to vac out is all right in the middle.
    JJ
