Results 11 to 20 of 28
Thread: Opening pool with massive algea growth
    Default Re: Opening pool with massive algea growth
    added 3 gals of last night brought TC up to 22.5 CC 1.0 FC 21.5, this AM before the sun hits pool I had TC 11 CC 2.5 FC 8.5. Lost 12.5 PPM before the sun. Only lost 7 PPM all day long during the sun. The increase in CC has me worried. Should I add even more Chlorine? I calculated that I would need 5 gals to hit the breakpoint of 25 ppm with the CC at 2.5 ppm.
    BigDave's Avatar
    I don't see a CYA reading - presumed 0 but no measure. Given the gret loss of FC, the CYA has probably been converted to ammonia / urea. I don't know if you really want to go to 25 with no CYA - what kind of pool do you have?
    Yes, keep adding chlorine - it and sunlight will clear the CC and algae, keep it at shock, test as often as you can and bring it back to shock.
    CYA tested at Pool store at 12. Its an inground vinyl lined pool.
    There is no way a pool store can get a CYA reading of 12. That test is just too subjective and you actually can't differentiate values under 30. We see this all the time.
    The pool was opened with zero CYA. I tested for it. Before I realized about the degradtion of the CYA I was adding CYA by way of TriChorl pucks in a floater I made. So there could be a low reading of CYA. I have taken the Tricholr out while I battle. Todays readings are after adding 3 gals last night.
    Last night after adding 3 gals
    TC 19
    CC .5
    FC 18.5
    This AM reading TC 16
    CC 1
    FC 15
    Only used 3.5 PPM last night down from 7 overnight two nights ago and down from 12 from just one night ago but it was distorted by the 2" of rain we had that night. Still brushing every day and backflushing too. Making slow progress.
  6. #16
    What she means is that there may be a low level of CYA in the water, but the black dot testing for it won't differentiate between levels of CYA less than 30 ppm.
  7. #17
    Update for today; Added 3 gals last night ended up with the following readings. TC 18, CC 1, FC 17; This AM had TC 15, CC 1, FC 14. This is the forth day of 3 gals/day chlorine addition. Is this normal in the battle to clear up the mess from the degradation of the CYA over the winter??? Been losing 3 to 3.5 ppm overnight the goal is just a 1ppm loss correct?
  8. #18
    BigDave's Avatar
    Sounds pretty normal. It taks alot of chlorine.
    Stay at it, the fact that you're losing FC overnight and have a significant CC level indicates you're battling something.
  9. #19
    Would I help the cause by upping the dose to 4 or 5 gals overnight? That would be roughly 25 to 30ppm vs. the 18ppm that I am adding with the 3 gals? CYA is very low 10 or less.
  10. #20
    BigDave's Avatar
    I'd be concerned about bleaching your liner. Can you dose an extra gallon in the morning?
  1. Massive algae issues
    By Luke978 in forum Dealing with Algae & Slime
    Last Post: 05-03-2012, 11:24 PM
  2. algae growth
    By kechefs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-15-2010, 10:17 PM
  3. That massive pool restoration project
    By peppercorn in forum In-Ground Pool Construction and Repair
    Last Post: 01-04-2007, 10:10 PM
  4. algea in pool
    By tara15 in forum Dealing with Algae & Slime
    Last Post: 09-02-2006, 07:26 AM
  5. First algea in new pool/spa
    By mkelley in forum Dealing with Algae & Slime
    Last Post: 07-25-2006, 07:56 PM
