Order of adding chemicals - question
Order of adding chemicals - is the only reason to add chlorine before the stabilizer the concern of having to use more chlorine if you are having a possible problem?
If someone added stabilizer and then a little later the ph down but didn't realize that they should have added the chlorine first, can they go ahead and add the chlorine after that - since the pool needs chlorine?
Appreciate any thoughts on this so I can go put chlorine in the pool...
Renee
27 ft x 52 in AGP
Hayward Power flo LS 1.5 hp - Hayward model s180t sand filter
27' round 17.2K gal AG pool; hand fed; Hayward model s180t sand filter sand filter; Hayward Power flo LS 1.5 hp pump; 24/7hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; orig. truck but use well to resupply; summer: ; winter: ; ; PF:7
