It's the pool, not the numbers. There's something to be said for your husbands' point view: if the chlorine is OK, the pH is OK, the water is clear and you are able to maintain chlorine levels . . . GO SWIMMING!
Whatever else sodium bicarbonate (alkalinity increaser) will do, it will NOT clear cloudy water. Your pool store girl is a pool chemistry doofus.
