Results 1 to 10 of 26
Thread: Cloudy water
    May 2012
    Florida
    Default Re: Cloudy water
    Water tested at pool store shows
    TC 9.9
    FC 9.9
    CC 0.0
    PH 7.4
    TA 125
    CH 130 low what's recommended to get this up?
    CYA 50
    Dissolved solids 650
    NOTE: Stopped at Dollar Tree and stocked up on Bleach as it was only #1 there but noticed when I got home and read label it only has 2.75 % sodium hypochloride. I looked at label from one I got at Winn-Dixie and it didnt have any percentages on it. Guess I thought 6% was standard but will surely check from now on.
    15 ft Intex 3200 gallon agp. Intex GP53366EG 2500 gph pump with size B filter as of 5/21/2012. Used 1000gph pump before that for 2 yrs.
    6% bleach is standard but it is not uncommon for some of the dollar store type places to have lesser percentages of bleach so it is not always a good deal.
    You do NOT need to raise your calcium hardness in an Intex pool.
    May 2012
    Florida
    I read about the calcium in BBB method after I posted. See, those pool stores tried again I think he was surprised when I walked out without his recommendation.
    So do the numbers I posted look good and should I just keep adding the bleach and cleaning the filter?? It seems to be getting a teeny bit clearer but this has been going on over 3 wks now. We've been getting a lot of rain in FL tho.
    May 2012
    Florida
    I can see the whole skimmer hose......WOW, it's starting to clear. Just wanted to share some good news.
    One more question. Has anyone thought of doing or did disconnect the skimmer hose from the bottom of the skimmer basket and let it go to the bottom so it would intake water from the bottom of the pool? It's easily reattached to the skimmer basket to get stuff off the top.
    Quote Originally Posted by poolpuppy View Post
    Wouldn't it just be easier to attach a vacuum and do just that instead of disconnecting the skimmer hose?
    Glad it is starting to clear up!
    May 2012
    Florida
    I am glad its clearing too and thanks to you guys and gals I think "I fought the pool and I won"
    When I don't have time to vacuum it just thought detaching the skimmer hose and putting it on the floor of the pool would help and it could run for hours that way. I was just concerned that it could pull too hard on the vinyl lining if it reached the bottom. I was just wondering if anyone had done it.
    May 2012
    Florida
    One more question. Has anyone thought of doing or did disconnect the skimmer hose from the bottom of the skimmer basket and let it go to the bottom so it would intake water from the bottom of the pool? It's easily reattached to the skimmer basket to get stuff off the top.[/QUOTE]
    Should I repost this in the Intex Pool section since I've had no responses here?
    BigDave's Avatar
    I think you may be the first to try it (or at least post about it). This is an Intex forum so it seems like the right place to me. Maybe if you left the skimmer housing on the hose (not the basket or float) you could reduce the risk of catching the liner in the suction.
    May 2012
    Florida
    Tried putting the whole skimmer housing, per Dave's suggestion, on the floor of the pool today and it seemed to get the cartridge filter dirtier. Been able to see bottom of pool for few days now but still a little cloudy
    Should I continue with 1/2 to 1 gal bleach per day til completely clear?
