Thread: Anyone have any information on Solarmetrics SP20 solar heater controller?
    May 2012
    Ontario, Canada
    Default Anyone have any information on Solarmetrics SP20 solar heater controller?
    Hi, does anyone have a troubleshooting guide and / or more information available on Solarmetric solar heating controllers?
    We have a Solarmetric SP20 solar heating system which is not working anymore. The control unit powers up and the valve does work but in the 'automatic' setting, it never turns the valve so that the flow goes through (the manual position and the off position do make the valve rotate as desired so I'm wondering if one of the sensors or the board is bad but I do not know how to check that). I found one online supplier which appears to have some parts but they really don't have much information or description of the parts.
    Let me know. Thanks,
    Mike
    May 2012
    Ontario, Canada
    Default Re: Anyone have any information on Solarmetrics SP20 solar heater controller?
    Turns out that it was a really easy - over the winter one of the contacts on the sensor on the roof broke, I just had to fix the connection and now everything is working okay again.
    Thanks for talking the time to answer.
    It's often fastest if you can find the answer yourself. At least, I've found it so. Hope you have a good swim season!
  1. Recommended Solar Heater Controller
    By ArmyChief in forum Pool Electronics
    Last Post: 03-05-2013, 04:25 PM
  2. Replacing Solar thermal and natural gas with Solar PV and electric pool heater
    By California Newbie in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 08:14 PM
  3. solar heater
    By alexstjo in forum Pool Equipment & Operations
    Last Post: 06-03-2011, 03:38 PM
  4. solar heater
    By gregc57 in forum Pool Equipment & Operations
    Last Post: 09-19-2010, 08:50 PM
  5. Liquid solar blanket - information
    By Amir in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-22-2006, 06:26 PM
