Thread: Opening pool test results
    Feb 2012
    Pennsylvania
    Default Opening pool test results
    I opened up the pool for the summer and have been just been adding chlorine until I got my Taylor 2006 test kit. Well the test kit arrived and I came up with the following numbers.
    12 ppm Free Chlorine
    0 ppm Chombined Chlorine
    pH 7.2 (Needed 2 drops to acheive 7.4)
    160 ppm Alkalinity
    70 ppm Calcium Carbonate
    65 Cyanuric Acid
    OTO test kit (new this year) shows Chlorine as Orange
    water temp 70 degrees but feels colder than that.
    24 foot x 54 inch sidewall above ground pool
    Hayward Power-Flow Matrix 1hp pump
    Hayward Perflex Extended Cycle D.E. filter model EC40C92S with 38GPM Flow Rate
    Chemicals on hand:
    12.5% liquid chlorine 5 gallons (just purchased have not added any yet)
    Pool Brand quick disolving shock 99%Sodium Dichlor-s-Triazinetriane Hydrated (2 bags)
    HTH pH minus
    HTH Stabilizer and conditioner
    E-Z Chlor calcium elevator
    Pool Brand Alkalinity Booster
    Celatom brand DE
    Water is crystal clear, pump has been running 24 hours a day for approx 2 weeks. I have not added any of the shock chlorine for approx 1 week due to the orange OTO test.
    Any recommendations would be appreciated including how much of the 12.5% chlorine to use.
    Thank you.
    Greg
    Default Re: Opening pool test results
    Your numbers look pretty good except I would bump the pH up a little with some 20 Mule Team Borax (laundry aisle at Walmart). I would not use any more stabilized forms of chlorine in this pool since your CYA is already 65. I would just stick with the liquid chlorine for daily chlorination and for shocking when needed. I would not use any more of the dchlor.
    You also do not need the calcium elevator since this is a liner pool. Also do not add any of the stabilizer and conditioner. (That is CYA).
    With your volume, each quart of the 12.5% bleach will add about 2.3ppm of chlorine. Use that to help you figure out doses. With a CYA level of 65, you need to keep your chlorine level between 5-10 all the time and when you need to shock, you'll need to take it up to 20ppm.
    Hope this helps!
    Feb 2012
    Pennsylvania
    Thanks Watermom.
    In keeping the chlorine level at 5-10 ppm, how would you test for that because the OTO kit doesn't read that high (I thought I would save on the Taylor reagents and do the daily testing with the OTO kit)? Would I just use the test for the free chlorine in the Taylor test kit?
    I will get the borax in tomorrow to target the pH at 7.4
    Thanks,
    Greg
    You really would need to use your Taylor K-2006 kit to test chlorine levels higher than 5ppm. But, with CYA of 65, you might find that you don't need to test every day. Every other day might work as long as you don't drop below 5ppm by then.
  1. opening pool - water test results
    By mike_311 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-25-2013, 10:55 PM
  2. Opening the pool a little early. Here are my test results so far.
    By bri3180 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-19-2013, 01:24 PM
  3. Test results for Spring opening
    By iBrew in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2012, 07:19 PM
  4. Opening test results
    By Bnelson in forum DPD-FAS based testing
    Last Post: 05-30-2007, 06:51 PM
  5. Test results for opening
    By tjcat in forum DPD-FAS based testing
    Last Post: 05-26-2007, 09:12 PM
