Re: Water Level - HELP!
The question is: is the top of the pool level? If there's that much variation of the floor depth then it's kinda sloppy. If there's that much variation in top of the wall from level, you have a warranty issue. Is there water in the pool? If so, measure the distance from surface of water to top of pool wall (under cap or seat). If that's pretty much the same all around, you're OK.
