Thread: Water Level - HELP!
    Mar 2012
    Boston, MA
    Default Re: Water Level - HELP!
    Thank you all! Yes, you are correct in your advice to measure from the top of pool wall. We ended up calling a local installer and he advised the same and we measured and I'm happy to report that our pool is in fact level (within an inch) - thank goodness, I was stressed for a bit but as a new AGP owner I have a lot to learn. From the inside of the pool the ground is a bit unlevel but nothing too crazy. Thanks again.
    looking to buy an above-ground pool!
    Good news! By the way, update your signature with the details about your pool. Type, volume, type of filter, size of pump, if you have a Taylor K-2006, any other equipment, etc.
