Hi RMA;
The fact that the cartridge is stopping up indicates it is WORKING. Live algae stops up DE filters, and some cartridges: this is NOT a defect.
KILL the algae, and you'll probably solve the problem. And, once it's dead, you'll be glad for a cartridge that will filter out the dead algae, instead of passing it through.
To kill it, you need to know what your CYA (stabilizer) level is. Unfortunately, 'guess-strips' usually aren't accurate enough to help. Do you have a pool store that does a drops (wet) test for stabilizer? If so, have them test your water and tell you what your level is. If you read the Best Guess page (linked in my signature) it will explain what's going on.
However, to really get control of your pool, you need a good test kit. The HTH 6-way kit, available at some Walmarts, does not seem to be available in your area. You can check the link for yourself, however. Otherwise, you'll need a K-2006 -- again, see the link in my signature.
Meanwhile, as a stop gap, if you get a cheap OTO / phenol red drops kit, and check your pool. If the result is anything OTHER than dark yellow, add PLAIN 6% household bleach at the rate of 3 gallons per 10,000 gallons of pool water EACH evening, to maintain a DARK yellow reading. Unless your stabilizer is over 100 ppm, this will probably get things moving in the right direction.
One caution: if you have added a bunch of copper algaecide, you'll need to cut the dose by 2/3, lower the pH to 6.8 - 7.0 and let us know. Killing algae without also staining your pool may be a challenge.
