Results 1 to 8 of 8
Thread: Steps for a 54" wall above ground pool?
Threaded View
    Default Steps for a 54" wall above ground pool?
    My turn to ask a question for a change!
    I currently have Blue Wave Royal Entrance Steps that fit my old pool with 48" pool walls. (A picture of them at this link: http://www.inyopools.com/Products3/0...FeUBQAodZyNJow)
    They do not rest on the pool rail but instead on the decking boards. This evening, we dropped the steps into the new pool but they are not high enough for this higher wall -- 54". I searched and found that they do make a "pool step riser" that attaches to the bottom of this brand of pool steps but even if I buy that, it is still going to be an 11-inch drop from the deck to the first step which is too much. So, I'm considering getting new steps. Wondering if any of you have 54" pool walls and have any steps that you would recommend. I don't want a ladder. I want steps that attach to a deck.
    Thanks in advance to any who have suggestions for me!
  1. Above ground pool wall supports sinking
    By cuzzi in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2013, 10:08 AM
  2. Fiberglass track "receiver bead" coming loose from the pool wall
    By steve789 in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2013, 05:00 PM
  3. Crack in In-Ground Pool Wall
    By CapitalBoo in forum In-Ground Pool Construction and Repair
    Last Post: 04-10-2013, 12:23 PM
  4. Buckled wall of in ground Liner Pool
    By lakestlouispoolman in forum In-Ground Pool Construction and Repair
    Last Post: 07-14-2012, 08:47 PM
  5. Small "BB" sized hole in my above ground pool wall
    By The Raddish in forum Above-Ground Pool Construction & Repair
    Last Post: 04-19-2006, 12:31 PM
