Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: New Intex owner from Texas
    May 2012
    Dallas, TX
    Default New Intex owner from Texas
    Hi!
    Well, this is my story:
    This is the equipment I have -
    Intex 18'x48" Metal Frame above ground pool, 6,423 gals.
    Intex Sand Filter Pump, Model SF20110, 2,650 gph
    Intex Krystal Clear Saltwater System CS8110
    Set it up late last season, seemed ok. Water got skunky green over the short winter, and had a lot of winter rain for Texas (we needed it badly). This is my first pool, so am still learning on it.
    Spent the last three weeks shocking, cleaning and algeaciding the water. Got the salt level correct, PH at 7.5, alkalinity at 120, and CYA at 30, but couldn't get it to hold any chlorine. De-scaled the anodes in the SWG, and changed the sand in the filter. Googled around and landed here where I read that too much ammonia would eat up the chlorine, and it might be better to drain and start again. Water was blue grey cloudy and I just couldn't get it clear.
    So, thats what I am doing today, draining the pool. I bought new sand and will change it out and refill tomorrow. After reading some things here, it seems like you guys aren't real sure about the salt water generators. I guess I'd like to read up and get advice on startign the pool up without all of the salt first and then go from there and decide which way to go.
    Now, is there a pool test kit that doesn't require color matching, for us red/green colorblind guys? Even my wife isn't too sure about matching the test strips, and we had a small 3 test kit last summer. I'd like a recommendation prior to picking up something.
    Ok, gotta go read up on your BBB method now. The thread "Pool pH is at the "ideal" level, but alkalinity is super high" caught my eye and I thought this might be the best place to get real answers.
    Thank you for having this forum!
    Default Re: New Intex owner from Texas
    Let's start here:
    Do-I-Need-a-pH-Meter-(Am-I-Color-Blind?)
    If you get the K2006, you can do the chlorine (red to clear) and CYA tests (disappearing black dot) if you can see black and white only. The pH test does require color perception, but if you DO need to order a pH meter, let me recheck sources before you do so. Anyhow, do get the K-2006. She can do the alkalinity and calcium tests for you, if they are needed, which won't be too often on an Intex. (See the test kit page in my signature)
    Next, check your sand levels, and make sure the filter is full.
    Once you've done those things . . . we can talk about using floc. But it's a tricky process, and you'll need to get testing down, first.
    May 2012
    Dallas, TX
    Ok, I do have a basic hth 3-way test kit so I can do the basic phenol/OTO testing. I was hoping that by draining all water from the pool and pumps, changing out the sand, and letting the pool liner dry out, and refilling with fresh water I would be basically starting over from scratch and wouldn't need floc or a clarifier.
    18'x48" Intex metal frame AG pool, 6,423 gal; Pump & sand , Model SF20110, 2,650 gph; Krystal Clear Saltwater System CS8110, K-2006 kit. OTO kit
    18' round 6.5K gal Intex AG pool; swcg; Intex Model SF20110 sand filter; Intex Model SF20110 pump; 6hrs; Taylor K-2006; utility water; summer: ; winter: ; android tablet; PF:19
    Doing a complete drain can destroy a liner, so it is not usually a good idea to do so. Also, there is no reason to change out sand unless you add something that gunks it up like doing a conversion from Baquacil to chlorine, etc. I am on the 12th season with my same sand. I have topped it off a couple of times but that is it. Take Ben's advice and get the Taylor K-2006 kit. You need to be able to test for more than chlorine and pH and the good kit will test for everything you need.
    Good luck.
    Watermom, he's got an Intex -- those can be drained safely.
    Rock, it's been a long week, and I wasn't paying attention either. If you drain and refill, you can do just as you say, and will not need floc.
    Watermom is also correct that you probably don't need to CHANGE your sand -- unless it's tacky/sticky or in clumps -- you just need to top it off.
    Sorry!
    Sorry!
    Now I see that! I missed the part about it being an Intex. Ben is right. It has been a long week. What do you think, Doc? We've answered -- what? A gazillion or so posts this week??
    May 2012
    Dallas, TX
    Well, thanks for your dedication to helping others, guy (and gals)!
    Yeah, it's pretty easy to drain, I put four hoses in it to siphon the water off down the hill. Have spent the morning brushing the liner bottom and getting out the last of the water. I'm refilling and smoothing out the bottom liner right now.
    The sand filter change was like $10 and 20 minutes of my time so I thought it would be better to get rid of any bad water in it that I could. No big deal to change it out.
    I will order a K-2006 kit later today. Have to go get ready to go to my son's Baccalaureate right now.
    May 2012
    Oklahoma
    Welcome to the forum, I am pretty new too. My only two cents is get the big Taylor 2006 kit, I believe it is the 2006C. It has plenty of fluids to do many many tests of your pool. Once you get accurate readings from the Taylor kit, then the really experienced people here can really help you out.
    My experience THIS year with the help of the forum is better than it ever has been before. What I mean is, last two years I have used the Intex SWCG system (same one all three years now), all it did was add small continuous amounts of salt each week to keep my low salt beeper from coming on. The change this year is knowing and understanding what CYA is and how it works in my pool. So far, my salt level has not changed since my original fill almost a month ago. I positively know it because I have the test data to prove it (the Taylor Salt kit also available from PoolDocs web links). And I can see my chlorine go up and down and I know why and what to do about it.
    Again, I am on the new side here, there is some very wise people here who have SWCG systems. My take is, I like my Intex system, but I know now that there will be adjustments to be made, that's where BBB comes into play. On my little pool, if I need to raise FC levels up a bit, I know a cup, yes, one cup of Clorox is all I need to do it, wait a little bit as in overnight for me, test and adjust if necessary. I didn't realize that how much I use my pool and how much it is uncovered in the sun changes my chlorine levels.....didn't know that until coming here.
    Enough of my ramblings. Here is what they told me and they were correct. Order the test kit, call back after you have the numbers.....great ready to have a wonderfully enjoyable pool this season.
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
    May 2012
    Dallas, TX
    Hello again!
    Okay, my K-2006 kit is on it's way. I filled up the pool on the 21st, measured on the 22nd the CL @2 and PH @ 7.5 with my hth 3-way kit.
    Wasn't able to tend to the pool because of work on the 23rd. Today, the 24th, it measures out at CL @.5 and PH @ 7.5 still.
    Digging through some of the recent posts, it was mentioned to start adding a gal of bleach per 10,000 gals of water every night. Would a gallon today, and a half gallon in the following evenings, be okay until I get the full kit in?
    I picked up at Wally World a 4lb bag of hth Salt pool care (cyanic acid). The levels it recommends are 4 lbs for 20,000 gallons. Would it be worth adding a pound of it now to help keep the CL or should I wait until I get the 2006?
    Also, I've not added any salt to the pool just yet, was wanting to see if I can get this going well and use the SWCG to maintain the CL levels, much like Bob E. is doing above. Very hot and sunny here in Texas.
    If you just filled it, by all means go ahead and add the stabilizer -- 1 or 2 lbs in a sock.
    If you water is clear, adding 1/2 gallon of plain 6% bleach should do you -- but you can't quit while you wait for the kit. Get a local OTO kit and skip adding bleach ONLY if the PM chlorine level is dark yellow.
  1. New 12' x 3' Intex pool in Texas
    By garry in forum Intex-type Pool Setup & Operations
    Last Post: 07-06-2013, 02:17 PM
  2. New Intex Pool owner...
    By mommabeans in forum --cleanup--
    Last Post: 06-07-2013, 03:45 PM
  3. New Intex Pool Owner and on a well.
    By virtualmech in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-18-2012, 11:30 PM
  4. New Intex Pool owner
    By tom79904 in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2012, 12:45 PM
