Thread: Decreasing CYA
Threaded View
  1. #2
    Default Re: Decreasing CYA
    For every 10ppm of chlorine that trichlor adds, it also adds 6ppm of chlorine. You can put trichlor in a skimmer. Ben says that it is ok as long as you never have the pump off for more than 8 hours before turning it back on because trichlor is so acidic. Because of its acidity, it also causes pH to drop so keep an eye on it while using the pucks.
    Did you do your own CYA testing? Did you use a disappearing black dot test? Do you have a Taylor K-2006 kit? If so, please add that info to your signature line.
  1. Pressure from Jet Decreasing
    By godstreasures1 in forum Pool Equipment & Operations
    Last Post: 05-12-2006, 10:43 AM
