Results 1 to 10 of 18
Thread: bbb advice
    May 2012
    RI
    Default Re: bbb advice
    Thanks for all the info. what i would like is measurements on raising ph, alkalinity, and chlorine by 1 for 20000 gallons.
    16x32 IG pool; Hayward pro series high rate sand filter; 1hp pump
    Lehigh Valley, PA
    www.poolcalculator.com is one source. There's also a bleach calculator in .exe format but I haven't used it since I don't run Windows. There are also a number of iPhone, iPad, and Android apps to help you calculate chemicals for your pool.
    In 20K gallons, each 1/2 gallon of 6% bleach will raise chlorine by 1.5 ppm. In the same amount of water, each 4 oz of baking soda used should raise your TA by 1 ppm. Can't be that exact for pH though--the higher the alk level in the pool, the more borax or acid it will take to raise or lower the pH. The lower the alk level, the less of each chem it will take to move the pH.
    Edit: Anna, your Post button is working faster than mine tonight!
    May 2012
    RI
    Thanks again, once i get used to this system, i think it will work out well. I have always just thrown stuff in but want to get it down right. just checked everything and my levels r perfect and the pool is crystal clear. Anna, I tried that pool calculator and didnt care for it. I think im on the right path now.
