Results 1 to 10 of 12
Thread: Help with pool resurfacing options, new user
    Default Re: Help with pool resurfacing options, new user
    My general rule: the longer the warranty, the more bogus the product.
    If it's got a 50 year warranty, stay the heck away! No company can reasonably offer a warranty that long, so you already know that -- as company policy -- they chose marketing over honesty.
    Sean OBrien is offline ** No working email address ** Sean OBrien 0
    May 2012
    Fort Walton Beach, FL
    Sort of a similar question in this regards...
    Have you ever used any actual fiberglass repair materials or is it most common to paint the fiberglass with a paint (epoxy or otherwise)? I will be tackling the issue later rather than sooner - but I am looking to get a hold of as much information ahead of time so that I can make needed arraignments.
    Just as an example of how we would handle a regular fiberglass issue (not on a pool - but a boat or car). First we would sand down any remaining gel, paint or clear coat finish in order to get to the fibers. Once that is exposed, we would clean it up with a solvent (works a bit like purple primer for PVC...prepares the old material for new material). If the fibers are in good shape still, we will apply a thin coat of vinyl or polyester resin (depending on what the original resin was). After that it would get sanded smooth all over the repair area. Finally a couple coats of gel coat would be sprayed on to protect the underlying resins and provide a color coat. If the fibers themselves were actually damaged (due to something puncturing or tearing through a boat hull or a bumper for example) the bad area would be cut out and a plug would be formed to support new mesh. The edges of the old fiberglass would be ground down to a knife edge taper. The plug would be fit behind the hole and new fiber would fitted over the opening (several layers in order to build it up to the original thickness). After that, it is treated like the other repairs (resin, sand, gel coat).
    On repairs like those which I have done in the past they have held up quite well in their given applications. Normally, just as well as the original unless you have issues with materials or prep work. Considering that the original pool panels have lasted as long as they have - I would assume that refurbished materials would last as long again (definitely more then 6 years). Again though, the stuff I have had to work with either floated in regular water (salt and fresh) or was on the road. The chemical bath likely does play on the fiberglass - though I am not entirely sure how quite yet. Since PVC seems to be the plastic of choice for the plumbing though and I have used PVC resins for FRP work...I would imagine something more permanent can be done.
    Of course then the question ends up being the cost of having it done for you for those who prefer to do things that way. I know what we charged to reglass the bottom of a boat, although the pool is a much easier shape to work with - I would imagine that you would be looking at a pretty descent sized bill.
    Apr 2012
    NE Oklahoma
    My experience is with fiberglass boats but have some suggestions. The blisters need to be ground down. It is likely just the gelcoat that is blistered but blisters can form between the fiberglass layers as well. We will assume it is just the gelcoat. Anyway, you grind off the raised blisters and feather the edge of the ground area. You can then fill the defects with epoxy that has a fairing filler added. This thickens the epoxy so it is more putty or spackle like so it can be spread in the defects. Then you sand the repairs smooth and prep the rest of the shell and then paint with the aforementioned paint. This would be time consuming but pretty easy and you could do it yourself. I use West System epoxy for boat repairs and they have pamphlets that clearly outline how to do repairs like this.
    The other option would be to remove all of the existing gelcoat and then redoing the entire shell with new gelcoat. This would be a big job obviously.
    May 2012
    Indiana
    Thanks for the help. I will be taking your advice on patching the blisters, as they do seem to only be in the gelcoat, not between the layers of fiberglass itself.
    18 x 36 kidney concrete pool with fiberglass walls.
    May 2012
    Indiana
    Smile Re: Help with pool resurfacing options, new user
    Ok, I have a new question that relates....what about converting to a vinyl liner? It may cost a bit more, but should last longer/be less risky, right? Anyone done this before? I'm unsure of three things: 1) How the liner track would secure at the top of the pool? 2) how to convert the skimmer/return fittings to work with a liner, and 3) getting the custom made liner to fit nicely, because the pool is such a strange shape. Thoughts on any of this? Thanks!
    It's been done, but I've never seen it done myself, and don't know how well it can work out. I feel pretty confident, however, in say that if you can't find someone local to you, who's done it SUCCESSFULLY before, you should rule out that option.
    Mar 2012
    No. California
    What about a spray on liner..like the Rhino coatings?
