Thread: Above ground SWCG vs In-Ground SWCG
    May 2012
    OK
    Default Above ground SWCG vs In-Ground SWCG
    Hello! In the process of purchasing a new AG pool, either30' or 33'. I've decided to go with a SWCG system, and wonderif there's any reason that I couldn't plumb in an SWCG intended for in-ground pools. Am I missing sometjing? Thanks!
    May 2012
    OK
    Default Re: Above ground SWCG vs In-Ground SWCG
    Yeah, and my understanding is that it's due to the possibility of corrosion from the presence of salt. I'm buying a good quality galvanized pool, so that should minimize most of the problems, but regardless this pool is just a temporary solution at the new house that I'm buying and moving into the first of July. I'll eventually be going in-ground, but that will likely be a year or two down the road. Thus my question, in trying to think ahead about equipment that I could purchase for this temporary pool that would also be able to be used on my future in-ground.
    Ft Lauderdale, Fl
    they should function the same, regardless of above ground or inground. Some above ground models may come with a specialty 110 volt plug or barbed fittings, but other than that, it's basically the same.
    Sean Assam
  1. Using an in ground cleaner in an above ground pool
    By Johnnymac in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-11-2012, 09:03 AM
  2. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  3. Filling our NEW AGP now, but need help with ground wire/ground field?
    By TheVanDams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 11:38 PM
  4. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  5. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
